The JK cluster has a plastic sheet across the whole piece that the numbers are a part of so without finding an aftermarket one that is swapped to the right side is like finding a needle in a haystack. You could always do a complete custom job but that may be more work than your willing to put into it. Good luck with this project. If you do find something post up some pics!
