There *might* be enough room if you can get creative with a mounting plate/bracket. The air filter is about 4 inches below the top of the, and the compressor outlet of the turbo is about 8 inches away from the side of the engine compartment. I forgot to measure from the fuse box forward to the power steering fluid bottle. There might be enough room there for the length of the box.
