No check engine lights for me.
If you have a boost leak at the IAT sensor, that means you also have a vacuum leak there when not on boost. Maybe that vacuum leak and the exhaust leak are causing your errors.
Where exactly is your exhaust leak? And how was it found? Any tips on checking for exhaust leaks? I'm still a bit paranoid that I might have a non-obvious leak somewhere.
Once you get the leaks fixed, maybe you should follow this procedure to clear the adaptive memory and put the computer into "fast learn mode": http://www.quadratec.com/jeep_knowle...article-89.htm
One possibility is that it the computer has some calibrations stored in there that are now incorrect enough with the turbo kit to cause error codes. Details on adaptive memory and "fast learn mode" are hard to find, so it's unclear whether the computer would eventually "slow learn" new calibrations, or whether clearing the adaptive memory is the ONLY way to get the computer to re-calibrate.
My exhaust leak was under the driver side, where the exhaust meets the cat back? Thats where the my installer found the leak. He found the black puff marks. I could hear what sounded like some air leaking.. i have an after market exhaust too, and before the turbo was installed the exhaust sounded nice and throaty.. its a Dynomax competition evo. And when the turbo was installed after driving it around i could hear some unusual sounds coming from the pipes that would sound like there is something not tightened well and air is leaking somewhere...its like a puttering sound at low speeds at the lower RPMS. Sure enough i took it back to my installer and he found a leak. I still think theres some leaks around the passenger side pipes, it just doesnt sound smooth and rumbly/throaty like it used to before the turbo. and at low speeds/rpms it should sound the same as it did stock before the turbo, and it doesnt.. So ill find out tomorrow when i take it to the shop. Im going to have them check thoroughly for boost leak and exhaust leak check all the sensors and just make her right like she's suppose to.. Also see if they can dial her in with automatic tune.. Ill keep you guys updated. Oh and another thing, pickles on the adaptive memory clear....I have the AEV procal, thats what i use to clear the codes.. will this method work better than the AEV procal as far as resetting the codes? Also i forgot to add.. I use the AEV PRocal ontop of the diablo intune. I use to calibrate my tires and gear ratio.. My Diablo intune does not have the Quick Adjust parameters that allows me to adjust tires and gear ratio. Dan and the guys have been trying to fix/update my Tuner... No luck so far so they told me to use the Procal until my Diablo tuner is working properly and they can get me quick adjust parameters download on to the tuner.. I think the Manuals benefit a lot more from the turbo as far as the tuning goes.. Hope this shop can help me tomorrow. Limited on performance shops here in New Orleans, even more with 4x4 shops. We shall see. Keep you guys updated.
