These are the offending bolts that offer so much of a challenge. Other than these, removing the stock shafts is pretty easy. You can see the limited access you have from below the jeep if you dont' have a lift. Hence why you lift the end you're working on up in the air. its pretty cool to be able to turn both 37s with one hand by rotating the driveshaft.
