You make it sound like it's as simple as adjusting some screws and suddenly you have a 400+, or even 800+ hp 4BT.
I did some browsing around on a couple 4BT forums, and the common relatively easy, affordable mods get you into the low 200 hp range without opening up the engine. Beyond that seems to start requiring serious engine mods (pistons, rods, machining heads, valve springs, aftermarket studs, crankcase bracing, bigger turbo, twin sequential turbos, etc., etc.).
I've also noticed that the diesels with huge power at the drag strip need to brake-boost for about 5-10 seconds to pre-spool the turbo before fully staging to begin the race. They do the same thing on the dyno too. That leads me to believe that there would be some serious turbo lag during daily driving if you wanted to tap into that big power.
Yes, a 4BT can make some huge power. But it takes quite a bit of money/work, especially if you want good reliable power. The same can be said for many engines. There's nothing magically secret about diesel for getting more power.
The Pentastar could likely make some similarly huge power if it was modified to the extent of these huge power small diesels. The stock pentastar already makes quite a bit more power than a stock 4BT. Bolt-on forced induction puts the Pentastar into the power range that the 4BT requires being rebuilt internally to support.
What the huge power modded diesel gives you though is insane low rpm torque. I know some Jeep people think low rpm torque is all the rage, but I'm pretty sure it would be safe to say that 800+ ft-lbs that requires loading up the engine to spool up the turbo to get there... would just be absolute complete overkill for off road driving in a Wrangler. That kind of torque is what you use for hauling *very* heavy loads. I know it's hard for you to remember, but this is a Wrangler forum. Wrangler's don't weigh as much as your deuce, so they don't need ridiculous amounts of low-end torque just to move around acceptably.
Final point: if the 4BT is so easy to turn up to 600, 700, 800+ hp as a reliable and good daily driver, and would be amazing in a Wrangler, then why isn't Bruiser doing it? Why does Bruiser only talk about being able to "turn it all the way up" to the 250-300 hp range? Maybe you need to call up Bruiser and let them in on your secrets to more power!
