Thanks. I think you've just proven my point. And that's all on top of a $21k conversion. And there's a lot of assumptions of "do all the work yourself" (bolt-on kits are one thing, removing and rebuilding an engine is on a whole different level of skills/tools necessary), and assumptions that you actually know what the hell you're doing with matching all the right components and settings up to support the big power (there isn't a simple complete kit for this). More realistically, you're going to need to work with a performance shop that has experience in modding the 4BT, and prices for various portions of the process will skyrocket. And in the end, reliability is a concern.
For about the same amount of $$$, you could do a 6.1 or 6.4 hemi conversion (pay someone else to do it, that is), add a bolt-on supercharger *kit* from a reputable manufacturer, no engine mods necessary, be in the same ballpark of power output, and have an engine that can be diagnosed/serviced by any Chrysler dealer. Plus the Hemi sounds much better. The 4BT sounds like a school bus or garbage truck. Not impressive :-p
