Simple is relative. You don't make 800hp or even 600hp at the crank shaft without some internal modifications:
1) Reduce Compression ratio from I believe it is 17:1 possibly 18:1 to 13-14.5:1 ratio (it will be a little harder to start, but still doable.). New pistons about $1000.00 maybe less depending type used.
2) Blue Print and Port The Engine That has to be done. Depending on how well built your engine is from the factory will determine how much this will set you back but it should be under $3K if you can do most of the work yourself.
3) Fuel injector pump have it rebuilt so you can get at least 800PSI to the injectors they will do the rest of the work for you. You want high volume and high pressure. So you need to have your injectors blue printed-- depending on the number and specs you have probably set you back with the injector pump another $2000-$2500
4) Turbos-- You start off with the first stage using the stock 4BT turbo then you put on either a Cummins 8.3 turbo or maybe one from L10 enigne either one will probably be more than enough to get you to the magic boost number of 200+ PSI!!!! Used pull out about $500-$1000-- rebuild kit runs about $250 to $500 depending on requirements.
5) Intercooler-- Probably air to air you can get one for about $800- $1000.
6) Water-Methanol System about $950.00
7) Wrap and insult the exhausts and turbos for each stage as well as the intakes. $500.00
How do you make the power: Compound (Two Stage) Turbo Charging. You use the smaller 4BT stock unit to as the primary turbo with a by pass value that is boost operated-- it reaches say 24PSI Manifold pressure bam it closes and spools up the bigger C8.3 unit or L10 Unit that then pushes up to the 60-200psi manifold pressure zone.
Again the price of the final product all depends on your ability to find good prices on things and perform a majority of the work yourself. Otherwise the price goes way up. But, to me this is easy.
This how Borg-Warner does it. A home-built setup will have more tubing and so on but it will work out the same way. Massive HP!!!!
Why doesn't Bruiser do it? Simple reliability always suffers with massive hp an torque. They want customers that want novelty but aren't exactly people who fix things on their own. So they keep the HP low and the Torque lower and this makes for greater reliability in all aspects of the vehicle.
