The only heat-related issue I have experienced with the turbo was excessive intake temps with the stage 1 kit (no intercooler) after back-to-back repeated attempts to race up a steep sand dune on a hot, sunny summer day. Not unreasonable, if you ask me. With the intercooler installed, I'm not worried about heat at all (of course, I'll still give it a break to cool down a bit after lots of hard driving on the sand dunes). I have monitored coolant temps and intake temps under various conditions and have not seen any evidence of heat being an issue to be concerned about.
A turbo timer isn't necessary if you're smart. Don't park it immediately after doing some full throttle high boost runs. If you just drive sanely when you get near your destination, everything will cool down quicker than idling stationary at your destination. If you do, for some reason, park soon after using all the boost, just let it idle for a minute or so (until radiator fan stops running on high speed).
BTW - turbo timer doesn't work so well on a manual transmission if you like to park in gear
One thing to be aware of with the Vortech supercharger is that starting it up at low temperatures can damage it, and is not covered under warranty.
Source: http://www.vortechsuperchargers.com/images/94.pdfIn order to achieve the low noise level of Vortech
superchargers, Vortech specifies manufacturing
procedures that call for minimal internal clearance.
These precise tolerances however are not
conducive to temperatures below 25° F. Therefore,
storing the vehicle in a heated garage and/or
employing the use of an engine block
heater/aftermarket engine blanket is required when
the vehicle is subjected to a "cold startup" in
ambient temperatures below 25° F. Failure to
comply with this may result in immediate
supercharger failure and invalidate the
supercharger warranty.
Warranty document also mentions that cold starts void the warranty: http://www.vortechsuperchargers.com/images/92.pdf
