No body lift required. Quite specifically, the downpipe interferes with the final 1.75" of stock suspension up-travel in the front. 1.75" away from completely bottoming out the front suspension, the front driveshaft will contact the downpipe. This is why they recommend a minimum 2" lift. More specifically, it is the 2" bump stop extensions that absolutely guarantee no contact. Prodigy claims that a 3/4" spacer lift in the front is enough to avoid issues for street driving (that's what they have on their test vehicle).
1) So be sure to include the cost of a lift (if you don't already have a lift) in the total cost of the turbo install for comparison to the cost of other superchargers. It's not a reason to automatically rule out the turbo as an option. A basic 2" spacer lift is perfect, and is relatively inexpensive (very quick google search finds kits in the $140-$285 range). If you only drive on the street, then the Daystar 3/4" lift may work for you, and that's only $40.
2) A lift does not "subtract power". Yes, it does alter aerodynamics such that a little more power be required to overcome aerodynamic drag at any given speed. But we are talking about a small lift that has minimal impact on aerodynamics. And we're talking about a minimal amount of power lost to that minimal change in aerodynamics. And we're talking about a turbo kit that can make over 400 whp compared the most powerful supercharger kit making 320 whp. This is not a valid concern.
