Results 1 to 10 of 244
    I think a complete 3rd gear pull is still better than an incomplete 4th gear pull. The difference in the results shouldn't be that big. You could compare the 3rd and 4th gear stock torque curves (plotted against RPM rather than speed) to confirm that there's not a significant difference.
    Give us the torque!!
    Here is the power chart the way pickles wants it....or as close as I can get it.
    The 2 superchargers are in 4th gear. The stock line is power in 3rd gear. I just laid the stock 3rd gear pull over the 4th gear pull and its pretty much the same line till the spot where the 4th gear pull hits the speed limiter.
    So this should be pretty close to accurate. BUT THESE TRUCKS ARE NOT ALL IN THE SAME GEAR.
Name:	JeepLab Magnuson Ripp Stock 3rd gear.jpg
    Torque is coming.
    Thanks for appeasing me
    I like how the stock dyno pull started down near 1000 RPM. All the "I need loads of torque off-idle or else it's useless for me" people are going to complain that we can't see the torque gains in the 1000-2000 RPM range. Then there will be conspiracy theories about how you purposely avoided charting that area with the superchargers because of the lack of gains there.
    Guess you have to start over :-p. When you get your hands on the Prodigy turbo, can you try to start that dyno pull as low as possible?
    YES!
    You realize, im not operating the truck on the dyno. Im standing 30 ft away. Then they email me the file. That stock dyno is at a different shop from the SC dynos also.
    I can ask them to start the line as early as possible I guess.
    Torque!
    Here's the torque chart.
    Same story as horsepower, Magnuson at the bottom, Ripp at the top.
    Both Kill the stock numbers by close to 100 lb/ft.
Name:	JeepLab Mag RIPP Stock Torque.jpg
