Here is the power chart the way pickles wants it....or as close as I can get it.
The 2 superchargers are in 4th gear. The stock line is power in 3rd gear. I just laid the stock 3rd gear pull over the 4th gear pull and its pretty much the same line till the spot where the 4th gear pull hits the speed limiter.
So this should be pretty close to accurate. BUT THESE TRUCKS ARE NOT ALL IN THE SAME GEAR.
