Sure enough they were swapped, Driver side had black connectors upstream and white connectors downstream. I checked the wires/cables and all looked good nothing melted or ripped. I switched them out, put the white connector o2 sensors upstream and the black connectors downstream. (when i pulled the downstream o2 Sensor out they were BLACK!..I think that means im burning lean..) Flashed the codes again with the Procal. Drove for a good hour and no Check engine light so far.. So we shall see... Thanks for the Advice pickles! Oh and dont be down about not being able to upgrade to stage 2 for a while...This will give Prodigy some time to further more prefect the tune when you're ready to upgrade.![]()
