Off topic also... Anyone running a 2012+ Auto transmission thats had their jeep or know of someone who was able to dyno the jeep in 2 wheel drive? If so how did they achieve this... Last time i had the jeep on a Dyno it was a nightmare.. Could not shift out of 1st gear on 2 wheel drive with the manual engaged.. Turned off Traction control and even pulled out the ABS sensors in the rear wheels.. No luck.. Had to dyno in 4Hi.. Even then we could not get an accurate dyno in 4hi in 4th gear.. The jeep kept downshifting.. Any advice would help.. Thanks.
Ill wait until the stage 2 upgrade arrives and have the shop install everything.. They will be doing a Dyno before and after the stage 2 install. Ill get Pictures and video when that does happen.. hopefully Dan ships my upgrade early next week.... and then install the week after... So 2 weeks.. i hope..
