Here is the basics:
(Ross if not ok to post this feel free to delete)
AX757 The Chamber Pro II
1 of 2 (Enlarge)
NEW FOR 2014 - IN STOCK & FREE SHIPPING The Chamber Pro II is a rugged six-spoke true beadlock wheel cast from A356-T6 aluminum.
Size 17" x 9" with backspacing of 4.06
It features an inner bead reinforcement that substantially strengthens the wheel.
Its dual valve stem setup allows the owner to monitor air pressure out on the trail while airing up or airing down.
The beadlock ring is manufactured from 3/4-inch billet 6061 T-6 aluminum and the underside features a vertical ribbing that helps keep the tire from slipping under extreme conditions.
The ring is attached to the wheel using Grade 8 zinc-plated 3/8 socket-head hardware that, when mounted, is flush with the ring.
Free shipping within the U.S.A, sorry excludes Hawaii and Alaska.
Bolt Pattern::
Powder Coating Options:
Email Friend
Price: $399.80
« PREVIOUS | NEXT »
  Reply With Quote Originally Posted by JeepLab
