Good morning. I am Wes from Prodigy Performance. I am reading these forum posts and I am very concerned regarding the translations here. Our dyno numbers are not altered in any way. Why is there not a graph from the same vehicle, on the same dyno before and after. Also the SC guys should have the same. Then all three should be compared with the same correction factors on the same dyno etc. This should be the only way to make a comparison. Dyno runs with anomalies should be disregarded and run again. They certainly should not get posted. This only leads to misconceptions regarding the products.
The baseline should be set and there must be consistency to even begin to make a valid comparison. Dyno results without SAE correction are worthless. Choosing the highest manipulated number is a no no. We have never manipulated dyno numbers and we currently hold all power records for the JK Wrangler.
2007-11 350+ RWHP and over 400lbft of torque @ 12psi
2012- present 360RWHP and 370+lbft of torque @ 9psi
I would like to answer any questions you guys may have. Let me know!
