Thanks jeff for the instructions, i have contaced Dan and he sent me the installation manual but yours better.
Just finished with installation with couple of issues:
1- Check engine code P0129 related to map sensor. I have updated the tuner. Might had to clear it and check again but a second issue is there.
2- A heavy leak between the turbine and the down pipe. (Clamp removed and i can see a space and miss match)
3- can't figure out the rest of the leak cause the second issue was the big and noisy.
I am tired now can't think, ill better rest and think later.
