Normal driving D is fine. If you want to get into it( as with all Ripped autos) you have to lift to shift. The 2 ways around that are to use the sport shift mode, or if you are going from a stop ( to test 0-60 times) push the auto stick over so that "1" shows then you can go full throttle and it will shift without hesitation
