Wow - so sorry to be reading this. How did they know the overfill was 3ltrs? Are they/you sure the A/F/R didn't lean out and cause detonation? This is important stuff. We learn tons from failures. Were you able to determine if the overfill put the rotating assembly in the oil? Did you get any trouble codes?
