Dang, sorry to hear about all that. I overfilled the oil on my VW Passat one time (which had a tuned turbo in it) and had a similar experience. I used a new oil suction device to pull the oil out through the fill tube. Nice product, BUT, you have to get the oil heated up first to pull the oil out. Well, I used it for the first time and nothing was really coming out, I freaked out thinking my car wasn't running with any oil, so I like any dumb idiot in this circumstance, instead of questioning the new gizmo product I bought, I dumped more oil in. After less than a day, I realized, I just doubled the amount of oil in the engine. I promptly drained it using the old-school method (drain plug) and then re-filled, and the car worked without issue for tens of thousands of more miles.
Regarding Jeep not covering the engine cost. By law, they have to *prove* that your modification did the damage. If we didn't have this law, then technically they could drill a hole in your engine block, destroying the engine, and claim it was because of YOUR modifications that the engine failed and not THEIR drill hole through the engine block that cracked the thing in half. If memory serves, I believe this is call the Magnuson-Moss Warranty Act of 1975 that protects you and requires that they expend the time and effort to prove their claim (http://www.impalasuperstore.com/naisso/magmoss.htm)
