To help find the source of your death wobble, remove your steering stabilizer all together while doing some low speed testing. The purpose of the stabilizer is to improve how the steering feels, not to stop death wobble. You should be able to hit a 2' pot hole at 60 mph and not get death wobble WITHOUT a steering stabilizer.
In my case, the entire source of my wobble came from a worn out passenger side tie rod end on my drag link bar and a worn out drivers side tie rod end on the tie rod bar. Since the tie rod end on the drag link passenger side is forged, I had to purchase a new drag link (went with a Synergy one.) For the tie rod bar, I ordered an OEM aftermarket replacement tie rod end for about $20. Put both on and the problem was solved.
I found both of these issues by using a set of pliers and putting them above and below the tie rod end and trying to compress the fittings. Each side had about 1/16" of play in them. If they were tight there, I would have jacked up the axle on both sides and then had someone move the steering wheel back and forth to see if any of the tie rod ends were lagging in movement at all. There is a good video on youtube showing this.
Point being... You can solve this yourself, and usually for cheaper than you realize. It takes VERY LITTLE wear on your tie rod ends to get death wobble. In all cases though, please don't go down the road of a beefed up steering stabilizer. That just masks the real problem. You should be able to drive the Jeep all day long without the stabilizer. In fact, I was just about to pull my stabilizer off in order to isolate a problem of the Jeep pulling a bit to the left now that I have my new upper/lower control arms on. Because I have a gas charged stabilizer, it doesn't auto-center at neutral but instead always wants to extend, thus, it might be the reason my Jeep always pulls to one side slightly, or it could be that I didn't get a measurement on a control arm right.
