That was, unfortunately, in 4HI because of some technical issue about the traction/stability control systems not allowing a rear-wheel-only dyno run.
My 27% drivetrain loss assumption gives about 345 hp and 350 ft-lbs of torque at the rear wheels for the 6.4 Hemi. This seems like a reasonable difference between 4WD and RWD numbers. Maybe? No idea, actually![]()
