Just a reminder that this is what all of your posts now look like to me. This helps prevent me from wasting my time trying to actually discuss/debate your mostly irrelevant, non-interrelated, and/or just plain incorrect points.Not derp derpy!
1) Duuurp Derpity duuurp a duuurp so duuurp can derp derpy derpy hodor no duuurp the derpity of the derpy. So, let's say you derpy a 4.5:1 derp derpity box on the derpy end of derpity derpity CS derpy-- duuurp derpity derp you 4.5 x derpy the derpity rpm. So let's say at 2000x4.5 derpy you duuurp derpity of 9000rpm. Derpity derpy derpy derpity on the derpy hodor duuurp derp 0.5-2.0psi in derpity derpity, but derpity is the big derp derpy you derp duuurp to get duuurp duuurp derp be derpy of derpity out at >2.1psi 10-15lbs-derpy of air duuurp-- derp is derpity derpity it hodor to duuurp derpity derpity and duuurp air at derpy low derp.
2) Derp Derpity is derpity derpy as duuurp at low derpy in an duuurp and duuurp at derpy derpy. So, let's say you duuurp in our derpy derpity at 14.7psi (derpity one derpy at sea duuurp) an air derpy of 50lbs-derp derpity hodor by derpity derpity. If duuurp is say 50% the derpity duuurp duuurp derpity for Duuurp Duuurp derp. So, derpity the derpy has 50% derp air derp in it it is derpy derpity to derp in 10-25 lbs-derpity of air derpity derp the derp derpy duuurp duuurp 20PSI to do so. So you can derpy duuurp derp duuurp derpity at duuurp duuurp. So duuurp to 65lbs-duuurp air hodor is an derpity of 15% in Derpity Derpity.
3) As the derp derpy its duuurp as it derpy RPM-- the derpity of duuurp duuurp to duuurp hodor and derpy Derpity derp duuurp derpity duuurp derpy! So, to derpy derp air duuurp the derpy you derpy to use derpity DERPY or derpity derpity derp an derp in the derp of the derpity duuurp- i.e. duuurp derpy duuurp derpy via derp derpy.
4) Derpity derpity duuurp not be derpity at low the end of the RPM derp... Derpity you can duuurp the derp and derpy derpy by derpy the derp of the derp and duuurp derpy to fit the duuurp.
5) The derpy isn't derp is odd-- it is the dip derp it derp is far duuurp derpy... The derpy is derpy duuurp. The Dip, derpity duuurp duuurp in the derpity derpity derp and the duuurp is no derpy as derp in derpy the derp air-derpity to derpy derp derpity to derpity the derp derp of derp. It derp be derpity Derpity derpy isn't duuurp to duuurp derpy derpy the duuurp Duuurp derpy of the derpity derp 2400-2900rpm. It is hodor the derp duuurp derpy but the derpy isn't duuurp up duuurp the derpity's own duuurp derp. It duuurp be derpity to derpy duuurp derpy. If you derpy is duuurp it isn't duuurp the derpity derp 300ft-lbs of duuurp at the derpy derp duuurp. Derpy is odd too.
6) Derpity I derpity the derpy derpity derpy derpity duuurp it derpy to use derpy duuurp duuurp derpity and get any derpity duuurp for duuurp. Derpy is duuurp derpity is derpity how the derp derpity duuurp the duuurp derp for a derp rpm and derpity has derp to do derpity the derpity of the derpity's rpm. The the derpity duuurp derpity be derpy at derp derpity derpity the derp derpity of the air duuurp derpity derp hodor. Duuurp, you derp to use the derp of the duuurp hodor derpity. But for duuurp derp out the derpity duuurp's derpity in rpm derpy derpy of the derp derpy-- derpy is duuurp hodor. Derpy derpity derpy rpm!!!
8) Not all derpity are derp derpy-- derpy, to derp derp derp of Derp Derpy, Duuurp Derp and Derp Derpity derpity derpity as Derpy Derpy...
9) Derpy, I'm derpity derpy to duuurp out derpity in the derpy you are derp derp derp the derpity. Is derpity duuurp it duuurp derp you're derp duuurp the derpy's VE but derpy derpy hodor derpy derp. Duuurp is the derp duuurp any derpity it has a derp derpy of derp derpity it derpy derpity duuurp derp derp and derpy it derpy off.
10) It's derp a hodor...
11) You do derpy hodor derp in derpy duuurp set to duuurp any derpity derp at all hodor derpity duuurp and derpity... Derpy is a derpy. Derp you derpity duuurp hodor duuurp i.e. you derpity derpity to duuurp is duuurp derpy derp derp derp derpy and hp at the derpity duuurp you derpity it and derpy do it derpity the derpity. Derp get derpy on the derpity derp and duuurp derpity it duuurp the derpity derp derpy it derpity the Duuurp and do the derpity duuurp. Derpy all you're derpity is derpy. But I can derpy you derpity for derp 33% duuurp derpity to be derpity derpity derpy duuurp you duuurp to derp 585HP at the Derpity for a 360ish WHP duuurp... You're not derpy 585Hp at the derp duuurp derpy derp duuurp derp to the derp derp. NRE is derpity derpity derpy of duuurp on hodor gas, but, derpity are duuurp derp derpity the derpity to do derpity duuurp of derp! Derp is not the derpy you're derpity derpity a derpity on duuurp and 93 derp gas. IT is duuurp derp you're derp 90-120hp at derpy and derpy duuurp 60-80hp.
If anyone thinks any of KaiserBill's points are valid or worth discussion, please re-post any specific questions you have that you would like me to respond to![]()
