Just wanted to share the results of my improved derpity script. The beginning of your post especially turned out well
As hodor say-- Derpity, Derpity Are You Derp??? You're derp have duuurp to do derp my derpity. A guy derpity I was derpity for my derpity. I was derpity derpity derpy any derpy you duuurp 30-40K in a derp it is derpy duuurp for derp derpy derp duuurp. It doesn't derpy how derpy it is derpity derp the derpity duuurp you derpity need to derpy duuurp on the derpy derpity derp Derpity is derpy duuurp and to be derpity derpity derp duuurp don't derpy derp duuurp derpity derp. Derpity was my derpy. If you're duuurp to derpy $30-$40K in a derp you derpity as derpity derp it a DUUURP!
You're in derpity duuurp derpy derpy derpity aren't you? The derpy is derpy no duuurp who derpity it and who derpity in it duuurp can duuurp. And the derpy is the derp will derpy you duuurp and derp on derpy derpity-- derpy duuurp derp can derpy derpity of as end derpy derpy!
Derpy, the derpy of my duuurp was derp derp if you want get duuurp derpy duuurp a derpity duuurp duuurp on duuurp derpy derpy derp derpity-- DUUURP is the way to go. All of derp is duuurp derpy to the Wrangler duuurp duuurp. I derpy derpity derpity, but the derp are all the derp and derp is derpity. So, derpy is why, I wouldn't duuurp duuurp to derpy a JK derpity a 3.9 4BT derp derpity derpy 440-500hp at the derpity derp derp 700-900ft-lbs of derpity for a derp derpity- it is derpity. Any derpity you duuurp derpity 100+ HP duuurp you run the derpity of duuurp derpy. But, if you can derpity fit derp a 3.9L derpy in the derpy-- duuurp derpity hodor you are duuurp and derp derpity it.
Could you derpy a kit derp Derpy or AEV derp is OEM derpity derpity duuurp-derpy HP and Duuurp duuurp-- hodor, hodor derpity do it all the duuurp. I could in derp derpity the Derpity of Derp Jeep Duuurp. I wouldn't derp I'd derp not derp derpity in duuurp derp.
