Results 1 to 10 of 47
    Here is the basics:
    (Ross if not ok to post this feel free to delete)
    AX757 The Chamber Pro II
    1 of 2 (Enlarge)
    NEW FOR 2014 - IN STOCK & FREE SHIPPING The Chamber Pro II is a rugged six-spoke true beadlock wheel cast from A356-T6 aluminum.
    Size 17" x 9" with backspacing of 4.06
    It features an inner bead reinforcement that substantially strengthens the wheel.
    Its dual valve stem setup allows the owner to monitor air pressure out on the trail while airing up or airing down.
    The beadlock ring is manufactured from 3/4-inch billet 6061 T-6 aluminum and the underside features a vertical ribbing that helps keep the tire from slipping under extreme conditions.
    The ring is attached to the wheel using Grade 8 zinc-plated 3/8 socket-head hardware that, when mounted, is flush with the ring.
    Free shipping within the U.S.A, sorry excludes Hawaii and Alaska.
    Bolt Pattern::
    Powder Coating Options:
    Email Friend
    Price: $399.80
    « PREVIOUS | NEXT »
    Quote Originally Posted by 2me View Post
    Open forum bud, Let it rip!
    As long as its not profanity or spam, I will not alter posts. If you talk to ATX tell them we want to know what the rings cost!
    Ask them the wheel weight too, or measure one on the scale! I'm curious about how much the beadlock really weighs. I"m thinking beadlock for next setup, or internal beadlocks for the current setup.
    it will be a marked loss in accelleration. Its not going to be 5 lbs more, it will be more like 10 at least.
    Just heard back from them:
    "The rings are $135.00 a piece (without hardware) plus shipping."
    Not to bad.
    Not to bad.
    ehh $600 shipped for rings is expensive, Im sure they are beefy, the only time you would buy them is when you were planning to sell the jeep so you could get a better price, but at $600, you might just leave them.
    Or buy brand new wheels for $600.
    Ugh and i just remembered that there are 5 wheels! $700 shipped!
