The only heat-related issue I have experienced with the turbo was excessive intake temps with the stage 1 kit (no intercooler) after back-to-back repeated attempts to race up a steep sand dune on a hot, sunny summer day. Not unreasonable, if you ask me. With the intercooler installed, I'm not worried about heat at all (of course, I'll still give it a break to cool down a bit after lots of hard driving on the sand dunes). I have monitored coolant temps and intake temps under various conditions and have not seen any evidence of heat being an issue to be concerned about.
A turbo timer isn't necessary if you're smart. Don't park it immediately after doing some full throttle high boost runs. If you just drive sanely when you get near your destination, everything will cool down quicker than idling stationary at your destination. If you do, for some reason, park soon after using all the boost, just let it idle for a minute or so (until radiator fan stops running on high speed).
BTW - turbo timer doesn't work so well on a manual transmission if you like to park in gear
One thing to be aware of with the Vortech supercharger is that starting it up at low temperatures can damage it, and is not covered under warranty.
Source: http://www.vortechsuperchargers.com/images/94.pdf
Warranty document also mentions that cold starts void the warranty: http://www.vortechsuperchargers.com/images/92.pdf
Damn UselessPickles...
Just when I thought I was out, you bring me back in! Just messing with you, I GREATLY appreciate your very thorough analytical perspective.
I really like the Prodigy Stage II, but to trick it out is very expensive and the installation looks like a bitch. I will take another hard look at Prodigy before I pull the trigger. I really love turbos and have extensive ownership experience with turbo diesels; all OEM setups, which makes me less comfortable with a retrofit. Your experiences with the early Prodigy minor durability issues my have stuck in my craw as well.
