The spring was in a small bag that came with the stage II setup. Nothing was on the spring to indicate the PSI that it represented. I just followed the instructions and replaced it. I believe if someone goes directly to a State II from stock - the correct spring may be pre-installed. On my setup and yours, the parts required slight modification (i.e. spring).
