Tread lightly-- I am treading lightly as 18500lbs of truck will do. I mean come on. The bigger the truck the less ecofriendly it is.
Tires: Well they aren't hard to get off the front with a proper heavy duty breaker bar and 2 ft pipe. The only problem is to remember Right Side of the truck has right hand threads and the left side has left hand threads on the tires. I use a couple of 20ton jacks and bring a serious amount of cribbage. The duals are more annoying but they can be done in the field. It is best to get to a flat spot and then repair the tires. As for the loss of a bead- not big issue since the tire is tube type-- yeah baby 1940's tech. But trying to reseat the bead in the split rims will probably get you killed in the field. It is best to put the spare on and fix in the shop with the tire cage-- that is unless you like being dead or maimed. Again 40's tech at its best!
Fuel consumption on the high is about 10mpg cruising at 50mph at 2400rpm if you do a 900 mile trip. Around town you get about 6mpg. The Trail Trucks maybe get 2-4mpg-- did you see how much black smoke-they had the injector pumps turned up very high.
